Alpine MRV-F345 $180 shipped
• 4-channel car amplifier
• 75 watts RMS x 4 at 4 ohms (150 watts RMS x 4 at 2 ohms)
• 300 watts RMS x 1 (channels 3/4 only) in bridged mode
• Alpine MRV-F345 4-channel car amplifier 75 watts RMS x 4 at Crutchfield.com
Alpine MRP-F300 $130 shipped
• 50 watts RMS x 4 at 4 ohms (75 watts RMS x 4 at 2 ohms)
• 150 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
• Alpine MRP-F300 V-Power Series 4-channel car amplifier 50 watts RMS x 4 at Crutchfield.com
Alpine PDX 1.1000 $300 shipped
• mono subwoofer amplifier
• 1,000 watts RMS x 1 at 4 ohms (1,000 watts RMS x 1 at 2 ohms)
• Alpine PDX-1.1000 Mono subwoofer amplifier 1000 watts RMS x 1 at Crutchfield Signature
JL Audio 300/2 v2 $205 shipped
• 2-channel car amplifier
• 150 watts RMS x 2 at 1.5 to 4 ohms
• 300 watts RMS x 1 at 3 to 8 ohms
• JL Audio Slash v2 Series 300/2v2 2-channel car amplifier 150 watts RMS x 2 at Crutchfield Signature
JL Audio 300/4v2 $250 shipped
• 75 watts RMS x 4 at 1.5 to 4 ohms
• 150 watts RMS x 2 at 3 to 8 ohms
• JL Audio Slash v2 Series 300/4v2 4-channel car amplifier 75 watts RMS x 4 at Crutchfield Signature
Alpine Type R dual 4 ohm 10” $140 shipped
• Ported enclosure 19*18*13
• Alpine SWR-1041D 10" subwoofer with dual 4-ohm voice coils at Crutchfield.com
Lightning Audio 6*9- never used- no grills- all hardware-model-B4.69.2TK
Speakers: B4.69.2TK $45 shipped
Nominal Diameter: 6" x 9"
Description Tweeter: 2-Way
Nominal Impedance: 4-Ohms
Frequency Response: 50Hz~20KHz
Sensitivity (SPL At 1W/1M): 90dB
Max Power RMS: 70 Watts
Max Power Peak: 210 Watts
Mounting Diameter: 6" x 8.7" (153mm x 221mm)
Mounting Depth: 3.15" (80mm)
3/4" PET Tweeter
Polypropylene Cone
Butyl Rubber Surround
http://www.lightningaudio.com/latech/library/2008/Speakers/1230-55272-01_LAB4_FullRange-MAN.pdf
MTX Thunderlink-- self powered sub --model XT110P-- all wiring included
$200 shipped
MTX Car Audio - X ThunderLink Amplified Subwoofer Enclosure
SELF AMPLIFIED
Power Output: 100 Watts RMS @ 4 ohms
THD+N (Distortion) (1 Watt):
Signal-to-Noise Ratio (1 Watt): > -90dB
Frequency Response: 39Hz-150Hz
Dimensions: 15-5/8” x 12-1/8” x 8-5/8”
Profile AP600 amplifier-new- no box. $80 shipped
Profile AP600 2-channel car amplifier 100 watts RMS x 2 at Crutchfield.com
Details:
100 watts RMS x 2 at 4 ohms (150 watts RMS x 2 at 2 ohms)
300 watts RMS x 1 bridged output at 4 ohms (4-ohm stable in bridged mode)
variable filters (low-pass from 50-250 Hz, high-pass from 80-1200 Hz, at 12 dB per octave)
variable bass boost (0-12 dB at 45 Hz)
stereo or bridged mono output
Tri-way capable (Tri-Way crossover required)
preamp- and speaker-level inputs
preamp outputs
fuse rating: 20A x 2
8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
10-11/16"W x 2"H x 10-5/16"D
