Loud 3-way Setup Suggestions
  • 7
Savackz
GA
I usually over-search these types of things but have been needing to redo my doors from 2 6.5s to something much more, and have always appreciated a good 3 way. I only have an 80prs as a DSP (I know it isn't everything, but hopefully it'll do) and then use the crossovers on either the amps or an external EQ. They are in a set of these doors (will buy factory doors from a junkyard) and I can always try and have the pillars done as well. I know some basics of 3-ways like what functions as what, but no one that I know of appreciates a solid set of doors that have actual midbass and just overall be loud as crap as well.
Budget: don't really have a specific budget, but obviously want the best bang for my buck; will be using 2 TS 150.4s if need be and a Rockford 250.4 for the tweeters more than likely.
TL;DR - read the post //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://i1318.photobucket.com/albums/t653/Zach_Carlson/78311602_zpshl3amixo.jpg
prv neos 6.5 in the kick on axis, 10 or 8 in doors. The power handling is ridiculous. bridging a ppi 900.4 to a pair and they handle every last bit and sound sweet with the power. so bridge the ts 150.4s and deaden your doors. The prv neos are actually VERY midbassy in a proper door even more than the pwxs but are waaay louder and brighter up top. Massive audio CT 2s german silk domes are my choice for really good sounding silk domes that can get loud and handle a lot of power as well.
Use a wideband as your tweeter and cross it as low as the 80 will let you. 1.25khz.
Any 6.5s should be able to hit that before beaming.
Sent from my SGH-M919 using Tapatalk
ya..that PPI 900.4 does well.I was trying out my Autotek BTS 7300s and they sounded very nice on the doors with a Kicker KQ9 EQ,worked well also
I have 240mil deadener in the doors
---------- Post added at 12:05 AM ---------- Previous post was at 12:04 AM ----------
What do you mean a wideband?
I have 240mil deadener in the doors ?
Most mids have break up or hard roll off at the top end. 12k and up usually plummets.
Some mids are designed as widebands to not have this issue and can be used from 500hz to 20khz with no issue
Zach, we have a 3-way system that you would love. It's been the Ford Mustang front speaker solution lately with great results, and I'm certain you can make it work.
Is there a way to tell which mid is designed like that?
Whoops. Post above this
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
5K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
Savackz
Savackz
GA
trumpet
    Jun 1, 2024
    May 31, 2024
