Loud crackling and whining high pitched noise at higher volumes!!! HELP!!!
  • 2
DropDownLowYota
My friend has a chevy colorado and I've been searching almost all day on this problem: on higher volumes, his speakers start to crack and a loud high pitched noise like a whine comes on and we cannot figure out what the cause is. I tried unplugging the RCA's on his 4 channel and turning up the volume and there is no noise when they're unhooked. First I checked the ground because that's originally what I thought the problem could be but then I figured since the RCA's are out and there's no noise, then that isn't the problem. Please help!
Something tells me your amp isn't tuned properly. Pulling too much gain can cause distortion at higher volume levels.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
You have a blown cap in the amp more than likely. Had the same thing happen to a soundstream amp.
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
4
DropDownLowYota
DropDownLowYota
Honolulu, Hawaii, United States
Syrisi
Decebal
    Jun 10, 2024
