Low Sound Output from Front 6.5"'s
  • 3
aquadump
I am getting barely any sound output from my front 6.5" speakers when I tune the balance on my head unit all the way to the front (which actually says it's the rear). Sound output from the rears is fine and the head unit powers the amp for the sub in the trunk with no problems but the fronts give me nothing. The previous owner told me someone broke into the car and stole the subs and amp and he had to get the audio rewired so I guess that's where the front and rear wiring got switched but I don't know why I'm getting so little sound from my front speakers.
Radios, esp the high end ones provide filters. a HPF or high pass filter allows only higher frequencies to pass through the speaker. IE so your front speakers dont play bass and the sub will have a LPF or low pass filter allowing only low frequencies to play so your sub doesnt play your highs, just the lows. if its set wrong it will play only the highest highs and not the midbass youre looking for. if youre wanting them to play bass then youre expecting too much out of the system. it could be 1 of 1000 things though. It could also be set correctly and the speaker is mounted wrong. say a 6.5 in a 6x8 hole or something to that effect. also if your doors are not sealed (most doors have huge holes in them from the factory so you can repair them) then the midbass wont be there (the door needs to act like a giant box similar to the way your subs have a box) .
Some don't have that option. But it does have an internal amplifier otherwise it wouldn't put out the 21x4 it claims to. Check the eq settings...
13
what ^ said. amp gain setting info, test tones are at the very bottom...
595
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
745
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
aquadump
aquadump
Syracuse, NY
nateberrier
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
