Low Temp Lifepo4
  • 3
illridge
CarAudio.com Recruit
29
4
usa
So lithium , specifically lifepo4 does not like charging in low temp environments.
I've heard you can put a small load on the battery and get it to warm up enough to accept charging.
So would you have better low temperature performance with you battery permanently having a .5-1amp constant draw...
Or is that not enough to raise internal temperature?????
yeah.. my rig is acting a little funny.
It will sit at 13.2V with the car off.
Sit at idle and sometimes my Alternator wants to wind up to 15v .....
It'll be 14.6-14.8 by the time it gets to the back with the jy40....
still.... it's riding the ragged edge of TOO HIGH voltage
what ^ said. amp gain setting info, test tones are at the very bottom...
462
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
626
Just for examples sake regarding electrical, I have 1400 watts total between both my amps and my system has no trouble running everything max...
27
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
illridge
illridge
usa
LongThrow
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
