LPF Help - can't turn off amp or headunit LPF
Teej
Hey guys,
I have a JVC KD-R730BT head unit and a Hifonics BRZ1200.1D. I have my head unit LPF settings (55,85,120) with no off setting, and my amp's LPF settings (I believe 50-210) with no off setting. Anyway, I want the sub to roll off around 80-100Hz, but I have a filter coming from both sources. I've heard this can be bad. Is this true? If so, I'll just put my sub on the "rear" channel, since the only sub specific settings on the head unit are volume and LPF, and I have a volume knob from the amp.
Hey guys,
Just turn the lpf on the amp all the way up. The Hu will do the work, so set it at 80.
Got it figured out! Thankfully a friend just found out about KunKonceptz UBT-20 terminal adapters that allow multiple connections to my type 94...
266
Turn the volume completely down and operate ot normally. This is to see if it is the built in amplifier that is shutting down. If the radio does...
That would be a function of the harness, not the HU, I think. Have you looked into a Maestro or iData interface? i would check with crutchfield...
12
490
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
486
Teej
Teej
Whippany, NJ
Jepalan
winkychevelle
    Jun 3, 2024
