Lr3 stock harden Kaman sound system
  • 2
Repacent
CarAudio.com Newbie
I ran a line out converter from stock sub to a Jensen 1000 mono block amp to a 15 image dynamics dual voice coil @2 ohms the box is sealed and is 1.5 cubic ft and It hits but I’m not happy so I have another 1000 watt insignia amp and two audiobahn 10s in a box wired in series if I where to install that stuff aswell will it make any difference I’m new to this if any of you could help me out and tell me how to set up the system for the best pounding bass how should I incorporate all subs amps and I also have a capacitor any suggestions
Dont mix different size subwoofers and amps etc. It just makes for a nightmare. Personally i would be changing out the Jensen amp as its probably not even making half of the power it claims it is.
If you are going to replace the HU, then the AC unit is not needed. As to which are good to use, I like the Kenwood Excelon, Sony, Alpine and...
6
341
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
610
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
394
Those NVX are very good indeed. I only have a leftover set because they were originally going into my brothers restomod 68 Chevelle SS and we...
568
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Repacent
CarAudio.com Newbie
Repacent
Goldendale wa
Cannonshane
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
