Made to order grills, rings, Equipment for mounting speakers
I made for you. Supporting rings, holding the safety net, body parts, the volume for speakers.Equipment for mounting speakers. aluminum only. Steel Grid (Grid choice for photo or describe the specification). Dimensions can be any on the design or brand din and wishes in the form of external processing of the front surface - Decorative risk, polishing, Can painting. It's simple. Price by agreement.
Several options for photo:
"][/url]
"][/url]
"]http://[/url]
"][/url]
[/url]
More photos of my work here:https://yadi.sk/d/AMNurCZOqpaY8
I don't need a subwoofer, just the grill. It's going into a boat and I need to cover the opening left over from a surface mounted Alpine SWR-m100. I'm replacing that sub with an under seat mounted FU 750.
You can draw a sketch with the sizes? even by hand.
So you just need to close the hole with a grill?
The hole is roughly 229MM
The hole was for this speaker (Diagram attached) https://pdf.crutchfieldonline.com/ImageBank/v20080624114900/Manuals/500/500SWRM100.PDF
like so:
19609012_m.jpg'%20alt='19609012_m.jpg'>
Also I don't want it to be a solid piece... I would like a trim ring with a grill. I want the hole open like a vent passing thru the screen
---------- Post added at 04:43 PM ---------- Previous post was at 04:43 PM ----------
Picture it as a speaker grill that doesn't attach to a speaker...
I got it
How many holes are needed?
Yes, what Dox said. The ++ -- makes it so you don't have to shove 4 wires into 2 connections. Convenient.
230
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
706
There is a good chance you could add some sort of Bluetooth or AUX input to a vintage stereo such as a 1978 Pioneer, maybe with a separate toggle...
717
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
896
Alexander612
Russia, Rostov region
SilverSquared
audiobaun
    May 19, 2024
    May 19, 2024
