Major Problems
  • 5
Thomas Nicolas
I Was Hearing Static And Engine Whine..
.. So I Went To The Installation Shop, They Checked It, They Said My Radio Was Bad..
.. They Gave Me A New Radio, New Grounds For The Amps (Hi And Low), New Ground For The Radio, New RCA's On Opposite Sides Of The Car Away From The Power Cable..They Also Tested Both Amps..
Everything Was Fine, Til I Pulled In My Drive Away, It Starts Again...
The New Radio Is The Pioneer DEH 3000IP
Subs Are Pioneer
Inside Speakers Are Kickers,
The Amps Are JBL
WHATS THE PROBLEM? PLEASE HELP ME...
I Was Hearing Static And Engine Whine.... So I Went To The Installation Shop, They Checked It, They Said My Radio Was Bad..
Subs Are Pioneer
The Amps Are JBL
start out by taking the shops stuff back to them. then I would start by checking all the ground cables under the hood making sure they are clean of paint and rust look for corrosion on and in the cable's.also some times the factory ground for the deck is garbage. I clean ground is your best freind. i had a grand am when i was younger and there was that super tiny ground from the battery to the fender well it was rusty and well small 600 watts had my lights dimming in that car once i cleaned and upgraded it never happened again
I had this problem, its why i bought a new radio. all the grounding is fine.. any other suggestions?
was your old deck a pioneer
i had pioneer with a bad engine whine turned out you had to ground the rca's.
read up on it i think it is something like a blown pico fuse.
if both were pioneer i am guessing the headunit.
can you hookup an ipod use stereo to rca cable direct to your amp for the speakers and turn the car on and rev it up and see if you hear the whine.
the deck is brand new, there shouldnt be a problem...
i had the same problem with my previous deck which was a pioneer.
I did the ipod directly to the amps and they work fine
ima take it to the shop tomorrow and talk to them about grounding the rca's.
I Upgraded The Battery Wire Since Its Like 2 Years Old, And The Sound Went Away..
Installer Said That The Battery Wire Just Wore Out, No Sure Why Tho..
He Also Grounded The Rca's For Me, Since He Even Since Its Highly Recommended.
After He Did That, There Seemed To Be A Sound Improvement..
They Did This For Me At No Charge.. And Did It Right Away, They Didnt Make Me Wait Cuz There Was Like 10 Cars In Front Before Me Waitin To Get Serviced..
You need to troubleshoot. I assume you have an aftermarket HU. I'd start there by running a signal from a phone or ipod (etc) to the RCA outputs...
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
941
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
869
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
Thomas Nicolas
Thomas Nicolas
Cleveland, Oh
Thomas Nicolas
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
