Maybe I just should give up-HELP
  • 2
humblejohn
5
house
Want double din hd radio. Started with Pioneer 7200 hd and had to return it because the screen was impossibly small. Reception of hd stations good.
Traded for Jensen vm 9324 which has a readable screen but the reception is poor. HD stations cut in and out. On rainy day I get no hd at all! I think something is wrong here. I hope this problem can be solved.
Is it possible that the reception on these radios can be this divergent? Is there a brand out there which is know for good reception? My budget is $350. Does Pioneer or Alpine enter here or is quality measured by price alone? Thanks in advance
Frustrated
pioneer and alpine make a better unit than jensen. try and sell or swap it for one of them but with a screen u can read. seems like an easy fix. u liked the pioneer u had just couldnt read it
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
839
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
7
949
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
11
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
The CT's are nice, That Sundown is a a frik'n beast!
7
947
humblejohn
humblejohn
house
Cruzer
