Mb quart formula series amps
I would step up to the Onyx or reference or q series. I have 125 w. Rms feeding mine and they handle it just fine. Just make sure you tune the amp right. When I get home I can look on sonic and tell you which amp would be better. I love my morels, make sure you deaden the door and put a deflex pad or similar behind it also for best performance. I run my eq flat on them and it sounds great.
the form and onx are not cea if that matters... they are about 5% under what they are rated at... the ref and Q ARE cea rated and do quite a bit over the rated and have superior x-overs... the Q can also be ran active....
Also, does x overs on the amp mean I don't need the crossover that comes with the morels? This is my first comp set that's why I ask
And I decided im gonna go with the q4.150
CEA doesn't mean much anymore considering it's rated so high anyways. You have any proof that the onyx doesn't do rated?
because you are new to this i would recomend running the crosover that comes with the morels, and maybe later run active. But yes you could run active with the crossover in the amp instead of the passive crossover that comes with it. Also with that 150 per channel you should be able to turn that gain down quite a bit and your amp should run nice and cool.
Alt isnt in yet but neither is the system, I'm going with a 250 amp dc power alt. If I go passive then how do I hook up te supplied crossover? Seems active would be easier afterall?
Active is not easy for the beginer and it is very easy to blow your equipment if you don't know what you are doing. The instuctions are included with the morels, and it is very easy to install the passive crossovers.
I have this 4 channel MB Quart Amp that I want to sell$150 shipped
MB Quart PAB-4100 (pab4100) Premium Series 4-Channel Amplifier
It is currently in my car powering the front stage on 2 channels and bridged on the other 2 powering a 10" sub
I always loved those **** looking *******. not bad price shipped either. If I had the money I would get it from you, but I gotta wait till tax time for my upgrades
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
I have a pair of telza audio 12" subs for sale great condition never ran over the 1k RMS rating. I'm willing to ship just need to know a area so I...
You can stream videos off of youtube. There are some videos of Japan, and some nature videos that are awesome to watch, and show off the...
213
The 8's have a frequency response of 40hz and up. So I would cross them over at 60hz and up. And crossover my subs at 80hz. That way I would get a...
Lowflyin
Sit on my face, B*tch
Lowflyin
FU JOSE, PA
dontbeaprix
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
