MB Quart ONX1.1500D amp
  • 3
it should be fine as long as you dont go nuts with the gain and clip it. and the big three in 1/0, upgraded front batt and possibly a small batt in the rear would be a very good idea
and if you want to go with any more power youll need to start looking into a h/o alt.
I agree with everything here. I'd only get the second battery if I were experiencing voltage drops, which depends on the current draw of the amp and your alternator's output.
i wouldnt trust the factory electrical system very far. do the big three just to be save, better to spend a little money on some 1/0 than to be replacing an amp.
Ok...thanks...i'll look up big 3 tutorial on youtube and learn it from there.
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
3K
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
Somchine13
Somchine13
St. Paul, MN
Somchine13
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
