MB Quart or Kicker Crossover?
  • 1
badstang123
Hey guys. It's been quite some time since I've changed anything in my system so I need some advice. I understand the concept of passive crossovers and how they work pretty well, but do not understand the components of them and what makes a good crossover. Previously I had a MB Quart P-Series 5.25" component setup for the rears in my Avalanche. The woofers gave out so I picked up a set of Kicker SS56.2 SS-Series components. I switched everything over but after doing so, began to wonder if there was anything to be gained from using the MB Quart crossovers. They have more tweeter adjustment but beyond that I really don't know.
My main concern about using the MB Quarts is the Kicker setup is 3 ohm setup and the MB Quart is a 4 ohm. From what i understand that will affect some crossover characteristics. Other than that I'm looking at a 2500K crossover point for the MB Quart and a 2800K crossover from the Kicker crossovers. If it was your car what would you do? Thanks for the input guys.
- Justin -
I did a little more research and some testing with a DMM. Turns out the MB Quart Tweeter is 6 ohms and woofer is 3.5 ohms. The Kicker on the otherhand, is a 4 ohm tweeter and woofer is 3.5 ohms. From what I've read, while the woofers would be interchangeable with either crossover the tweeters will not be due to a change of a half an octave from the initial crossover point. Again this is just my conclusion from my research over the past day. Can anyone confirm my conclusion?
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
3K
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
893
badstang123
badstang123
Los Angeles, CA
badstang123
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
