Mb Quart Q4.150 or Discus 4125 Hifonics ZXI 150.4
  • 1
SMFJ
Looking for an amp that will do 200+ at 2 ohms. I don't go by what the website/manual saws I use x(Amps fusing)*13.8Volts*0.70(Class AB efficiency)=
ONLY interested in FULLY/FLAWLESSY working equipment. Not so hooked on looks.
Budget: REVISED
Right at $140 shipped but I might be a bit flexible.
AMP WILL BE GOING TO A GOOD HOME WITH A VOLTAGE DROP NO LESS THAN 13.21 AND A USUAL OF 14.1.
Offer Up
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
584
I wouldnt spend the funds on that amp if you have no way of knowing it works or not. Id purchase another 4 ch for that kind of money. You just...
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
SMFJ
SMFJ
Albany, Georgia, United States
SMFJ
    Jun 1, 2024
    May 31, 2024
