Mechman 240 amp alt for ford taurus 02-07
Item(s) for Sale:Mechman 240 amp alt for ford taurus 02-07 vulcan engine
Item(s) Description/Condition:used works great
Price:$220 shipped
Shipping and Miscellaneous Item Information:for taurus with vulcan engine
Yeah I think I want it. I sent him a pm. We will see. I think the wiring is a bit dif but after looking around seems to be very easy as I did with the 2g to 3g
This will not work on your Bronco, it runs from the Taurus PCM (reason it's 02-07 and not 99-01 as well). I have this same alternator with an internal regulator added.
The only cars this one will work on are a 02-07 Taurus/Sable unless you send it to Mechman and pay $100 to have the regulator added.
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
89
336
rickmandick
Amherst, Ny
rickmandick
    May 31, 2024
    May 24, 2024
