SOLD Memphis MClass 4 Channel Amp
  • 2
Mzlady
OHIO
I'm selling a Memphis 16-MCA3004 4 channel amp, it is in good working condition with no problems. No I do not have the end caps for the amp. I'm doing a system change and this amp isnt in the plans so I'd like it gone. NO TRADES!! Asking $200 shipped OBO. NO LOW BALLERS. Paypal only! Here are specs and pics
Full MOSFET Design
Built-In Fully Variable High/Low Pass Crossovers
User Selectable 12dB or 18dB Per Octave Crossover Slope
RCA Bypass Output
Platinum Finish Wire Connections
Accepts 4 Gauge Power and Ground Wire
4-Channel MClass Series Amplifier
Compact Aluminum Chassis with Custon Black Pearl Finish
Gold Plated RCA Connectors
Full MOSFET Design
Fully Variable Crossover: HP/LP (40 Hz - 6 kHz)
4-Way Protection Circuitry
Optional Wired Remote Gain Control
Adjustable Input Sensitivity: 250mV - 5V
Dimensions: 18.5" L x 7.6" W x 2.4" H
Number of Channels 4
RMS Power (4 ohms) 75 watts x 4 chan.
RMS Power (2 ohms) 115 watts x 4 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 230 watts x 2 chan.
Peak Power Output 920 watts approx.
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.03%
Built-in Crossover HP (40 Hz - 6 kHz), LP (40 Hz - 6 kHz)
Signal-to-Noise Ratio 92 dB
Fuse Rating 25A x 2
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
5
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
Mzlady
Mzlady
OHIO
Mzlady
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
