Memphis MClass Amp issue
  • 2
baseballfan1066
So I own a Memphis MClass 500 Watt amp and the little light indicator comes on yellow and I'm not getting anything from my subs, turns out the yellow light means the onboard fuse is either open or blown, well now that I've got it narrowed down to that how do I go about fixing or replacing the fuse since I'm assuming its not one of the normal fuses you plug in, hence the "onboard fuse" indicator.
yep it's a normal fuse flip the amp over there should be a small hole in there you will find the fuse, this is on the older models you may need to take the bottom off on yours but it's an easy fix.
  • Locked
Oh, just for future reference. Put $800 OBO, or you will only get that $600, or less. ;)
4
https://caraudiobargain.com/audio-apex-cab-22-car-amplifier-monoblock-2200-watts-rms/ Since these are back in stock they're really hard to beat...
5
And the most important thing you've learned in life up to this point is to get offended on behalf of other people on the internet in the attempt...
18
5K
So recently I bought a Memphis prx1000.1 and installed it to 2 rockfordfosgate r1s'. Both svc and 150rms 4ohm. I wired them to a 2ohm load to the...
baseballfan1066
baseballfan1066
Apex, NC
goingdef
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
