Mid-Level Subwoofer help
  • 3
Fullthrottle8
4
CA
I'll just add a few guidelines then, sorry about that
- no bigger than 12" subwoofers, I'm looking for two, ported
- sound: I want good clean sound, but still want some hard hitting deep bass
- budget is $100 per subwoofer
- I plan on buying an amp as well
- as for an enclosure: anything that works wel with subwoofers
- I don't think this will be an issue, but I don't want any planet audio or boss crap recommendations
- if you recommend, can you please link one and tell me alittle about the sound and how it compares to other ones you may recommend
These are going in the trunk of a 07 Ford Mustang, so if that plays a factor in sound and such
Thanks so much!!
Probably not going to get anything mid lvl for that price. Entry lvl yes. But woth that budget look up sound qubeds hds200 series. I think the 10's are $95 and 12's $99. Going to be the best bang for your buck. Or ct sounds tropos.
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
8
651
gain set well below "Normal" and base boost is off completely
15
That was something I was going to try also to remove some of the gasjet from the front
12
Definitely hard to beat, but they're deep. Didn't know these were still floating around.
13
Fullthrottle8
Fullthrottle8
CA
mylows10
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
