Mids and Highs NEED HELP!!
Hey guys. few questions i have on mids and highs because when it comes to it, i get lost...im gonna be running a soundqubed 200.2 puts out 220x2 at 4 ohm and 340x2 at 2ohm.. gonna have 2 nendo pwx 6.5's ad one ft-1 super tweet per channel. To get a 2ohm load at the amp do I need the 4ohm or 8ohm speakers? or is 2 ohm load even possible wth the situation im in? like I said this stuff confuses the **** out of me..also what does 2ohm stereo mean? Any and all input is welcome!! there were a couple other questions that i had but i cannot even remotely remember what they were at the moment.... pm or reply guys thanks!
Problem is that you need 4 ohm Mids for a 2 ohm load. But you'll need another smaller amp for the tweets
so i need 4 of the 4ohm mids on the 2 channel, and maybe just run the tweets off my hu, or a small amp.. Even with ext crossovers i couldnt run the tweets on the sane amp?
No. 2. 4 ohm Mids each side and a small amp for the tweets the cross over he was talking about is a passive crossover. Like in a component set an electronic or parametric crossover needs an amp or 3 usually highs Mids or mud range. The mid bass and subs
2 4ohm mids is what I meant to say.. And ok looks like ill be looking for a small little amp for the tweets then. I appreciate your help man thanks!
If i was to go with a 4 channel, does that eliminate the need for the third amp?
I agree with DJ. Pro style speakers are designed for large ported enclosures and lack bottom end without an enclosure. Plus they tend to suffer...
Another factor for ideal sound is the drivers. Some are capable of producing lower frequencies and some better at highs. This is relatively...
I just bought a pair of SoundQubed QP-MR6.5 speakers powered by my Taramps DS440x4. My 6x9s blew when I got the amp because I tried to tune the...
Ive ripped out my SPL build in my truck a few months back now and have a temp setup atm. I am planing another SPL set up and rebuilding and will...
10
Stevenajpvv
Boca Raton, FL
mylows10
Decebal
    Jun 10, 2024
