Mild upgrade for our R53 Minis
  • 1
shorterthanrich
4
Boston
TL;DR: What 6.5" components & 6x9 rears are best these days for a minor upgrade to a stock 2004 Mini with stock head unit that give better SQ and more bass/midbass, and what is the best way, if any, to amplify them without replacing the head unit? Flexible budget, $300-$1k.
Hey folks, thanks in advance for any advice. 10-15 ago I was pretty into car audio, but I see that a lot's changed since I've been gone, and a lot of my memory has faded, so I'm back to the forum for advice!
My friend and I both have '04 (R53) Mini Cooper S JCWs with the base (not Harmon Kardon) sound system, and we both have blown door speakers that have finally pushed us to want to upgrade. We'd like to avoid changing the head unit, mostly because we really love the aesthetic of the interior of our cars, and I have the Monte Carlo 40th Anniversary, which was a very limited run, so I try to keep the look stock. Budget isn't much of an issue as much as time is since I have 2 young kids and run a startup so don't have a ton of free time to get super complex. But I could see us spending anywhere from $300 - $1k if it were worthwhile.
We prefer SQ over SPL, but I admit we definitely like punchy bass. We both had built custom 2x12 ported boxes for our Elemental Designs woofers powered by Cadence 1,500 Watt RMS amps back in the day, but the Mini just lacks the space for subs.
Here are my questions I'm hoping you can help with:
  • Is it even worth upgrading front components (6.5 woofer & 3/4" tweeter) & the rear 6x9s without upgrading the head unit or adding an amp? If so, what's good these days for a midrange budget?
  • Is it feasible/worthwhile to add an amplifier off of the stock head unit? Is this possible with stock wiring to avoid running new cable to the doors & rear?
Thanks again for any pointers - I just haven't had the time to sift through what's good these days and what's easiest for a minor upgrade to the stock system for better bass/midbass and better SQ!
Hello, I have a Peugeot 207 SE 2007 and would like to upgrade its existing car stereo. It’s a single cd fm/am radio and I would like to get...
That's not an amplifier designed for subwoofer use, it's a 4 channel designed for you primary speakers. Small $75 investment to get you where you...
639
i would not worry about the tweeters. They will never see anything above 20 watts before your ears bleed. your options with 4 channels would be...
4
765
Thought I would update this thread… Couldn’t login over the weekend for some reason. Finally got the Kenwood installed last Friday… Had a little...
32
3K
Are you planning on upgrading the alternator and add extra batteries?
851
shorterthanrich
shorterthanrich
Boston
shorterthanrich
