Missing information about old subwoofer
  • 2
Drakonins
CarAudio.com Newbie
Latvia
Hello!
I got 2 subwoofer/s from a friend few weeks ago ( SP-212L ) I was using it these days but I noticed that it's missing something and so I started to check settings for amplifier searching internet how everything works etc. ( I'm new to audio, car stuff ) I found that they are each 1000W, 4 Ohm and amplifier is 1600W. So here starts the problem, those subwoofers are kinda old and I can't find RMS for them. Today I found manual for my amplifier ( TX-1600N ) it's half broken few ports don't work so I'm not sure about how correctly wires are connected, (in few days I will look into wiring) it does work fine max~ volume with +12db boost, listening for 30~ minutes, it's loud, but missing some low notes which I think I know how to fix. ( problem might be with car stereo that doesn't allow lower then 80 hz) But the main problem is that I can't find RMS for subwoofers, If I will fix it or get new amplifier how can I know how powerfull It will be needed. (friend doesn't remember much about it, as it was in garage doing nothing for a few years) Maybe someone has had it and knows something about SP-212L subwoofer. + Any tips for me that I would need to know about car audio system.
Thanks in advance for the information!
5 times so far and probably counting. How many times are you gonna post the exact same ignorant nonsense, and not actually answer my question...
19
What size speaker wire would I need? would 16 gauge be ok or should I get 14? I definitely want to be on the safe side.
8
I have been attempting to study the true nature of why we tend to tune transmission lines and enclosures in general like we do, the nature of...
So, assuming that you aren't using an LOC and are using the hi-level (speaker) inputs, use the speaker leads off of any of the R/L speakers (front...
39
4K
There is the 16pin connector in armrest of my old mercedes 2006 S350. Any possible way I can stream music from my phone wirelessly(Bluetooth) or...
Drakonins
CarAudio.com Newbie
Drakonins
Latvia
Jesus Christ
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
