Misunderstanding of head unit wattage
  • 2
ac123
I have recently bought a car with an aftermarket system. Nothing major. The front two speakers are stock but there is a new head unit and a new pair of 6"x9" in the rear. Everytime i run the radio over 20 or so volume, the stereo cuts out. I was wondering if that has to be a problem with the wattage of the head unit. The head unit is 45wX4 channels and the 6"x9"s are 220 Max watts each, (440 Watts). Do i need a new head unit? if so what wattage do i need?
Wattage has nothing to do with why its shutting down. It is more than likely a wiring issue, could be a speaker grounding out, incorrect ohm load, bad ground to deck. it even could be a loose fuse in the fuse box but what it is not is incorrect wattage. pull the radio out and check your connections
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
412
There are a couple of options. You can use a marine bt unit. They come in the size of a hockey puck and can mount anywhere. This is the marine unit.
560
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
Avoid jvc 480bhs hard to see the display in the daytime even with the brightness all the way up also not as easy getting to the audio menu like...
5
684
I have a 06 grand Marquis. Looking at either Kenwood or Sony Apple play. Is it worth have a floating monitor? Pros and cons?
ac123
ac123
United States
speedfreek09
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
