mixing amp brands
  • 5
if im not mistaken those amps do power at different ohm loads.
and not trying to sound mean but if you have to ask a question like that are sure you know enough to try running 10k?
forgot that....kicker will do power at 2ohm and the sundown at 1
Kinda forgot about Kicker,and their 2 ohm power.That makes it a deffinate NO.
Even before that it was still a no though.//content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
Will it work? Sure.
Will the subs get equal power? No
As mentioned, power is more complex than a flat number. It is constantly changing. Those amps were bad examples due to the different ratings and load capability.
Try to keep all subs equal and all sub amps equal.
Thank you for all your help and I'll let you know how it all turns out. I'm putting it n a kia optima. I hope that it sounds as good as i think it...
10
Im not sure if this helps or is the correct way but I have 6.5 mids in the front doors and tweets in the pillars I used 2way 6x9s in the rear...
996
6
136
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
316
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
311
1loudZ71
1loudZ71
iowa
keep_hope_alive
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
