MLA Module Help
  • 2
CaddieJapan
Japan
I just purchased the MLA module for a Toyota vehicle. Question I have is regarding installation. Vehicle uses a Toyota Denso Alt with 4 pin connector. The pins are IGN (ignition), S Load Sensing (goes to voltage regulator in the alternator), L for lamp indicator, and FR which goes to the vehicle ECU. Which line do I need to tap into for this to work? Any info would certainly help, thanks all.
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
I agree; it doesn't. :) See my comment above on Tuesday at 4:08 pm; in short, I'll use the auxiliary port on the FM transmitter.
5
I see a couple "Wanted To Buy" AC206 threads on here. There's a new one on eBay right now...
I assume the plugs are if you have factory equipment like a amp, etc.
991
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
CaddieJapan
CaddieJapan
Japan
joselr3668
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
