Modded Atomic at-7000.1d
resko1
<<< 8" TC1000 LMS S3
1,154
Sheboygan,WI
atomic at-7000.1d
bought this with a bad output section. Common with these amps due to lack of board supports. Was sent to ampenstein after ampmedics couldn't fix it. Was also modified while there. He added active cooling to the output section, upgraded speaker leads with 4ga stinger hpm, covered the caps in kapton tape, replaced the chipset, and added 6 more board supports. Its completely bulletproof now. Still has 9mo left on its warranty from ampenstein. power ratings..
7000@1 ohm
4000@2 ohms
2000@4 ohms
clamped 8400w @ 1.13ohms, 14.8v
Been ran in my metro on 4-c&amp;d 12-350's with drop to 12v.
1200 shipped and insured
Need the cash for home improvements.
Really isnt all that power hungry. I powered it on 4 c&amp;d 94ah batteries and a 55a stock alt. never dropped below 12v. Did a 150+@28hz with 8 sundown sa8's in a no-wall setup.
That's burping tho. I would use it daily. Guess I could at 4 ohms. Lol.
Nope. That was for daily. 1 ohm nominal with rise to 2.1 ohms. 5min demos at full tilt and usually half to 3/4 when driving daily beating peoples knick knacks off their walls:)
Fantastic find. Thank you for sharing this.
14
resko1
resko1
Sheboygan,WI
resko1
