More subs need drop in recones like the HCCA
  • 5
JoeK
Ringtown, PA
By dropins i mean no glue required, just drop it in and screw it into place. This is the most genius invention to subwoofers ive ever seen, why dont more people do it?
AFAIK only HCCAs do it, can recone it in about 2 minutes.. availability of recones is a different topic though
offtopic: new HCCAs coming in 2013
the cerwin vega strokers do it also . think the recones are more expensive that way
AFAIK HCCA 15 recones are $150, thats not much more than others, a recone for my BL is $125
edit: $230, nevermind :x
kicker solo x's do it too. it's so convenient.
That it is. If i could fit an HCCA 15 in my car i would just have recones chilling in my spare parts box and just swap it out in less than 5 minutes
kicker was the oldest i remember, but you still need extra components to glue the softparts to, so they have something that you can bolt down without specific unit allignment. all of the basket and motor assemblies need to be nearly identical allignment, or have real loose tolerances(big gap) for it to work. so, either way you sacrifice for more unit build cost, or cut that down a tad by sacrificing performanc/efficiency. i think more builders would rather slide a jig in it and glue, which is easier to do with man, or machine. if you want to see more unnecessarily higher priced subs, or more lower performing subs that aren't as affordable, then it would be the idea to play with on a bigger scale. i, personally don't see the sales to justify it being more common.
boston has them all one upped with the replaceable voice coil no need to change the whole cone just the coil so it was easy to carry a couple different config's with you and the G5 was nice except the kapton coil former, I didn't care for that.
that's very cool, i never knew about that. honestly, recones scare me. i've never done one but at $100+, it's kind of an expensive mistake to make. i want to try a recone sometime but idk. i had a solo x before and i liked how i could just remove the cone and, if needed, replace it with another within seconds. i know it's probably not the most accurate way to recone but it was super easy
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
Funny how all these fancy order boxes are needed ..when i did a 151.9 with a single 12 in a simple ported box in the trunk on 4000 watts with a...
6
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
559
JoeK
JoeK
Ringtown, PA
bostonkid92
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
