motorcycle sound system amp help
  • 3
baggerproject
texas
Im currently in the middle of a build. I love Polk speakers and am going to be running them on my bike, however I need help picking out an amp to run everything I will be running 4 speakers on my front fairing and 2 speakers on my saddle bags.
the 4 speakers on my fairing are 6.5 inch Polk MM6501
RMS: 250 watts per set / 125 watts each side
•Peak: 500 watts per set / 250 watts each side
•Frequency response: 40 - 25,000Hz
•Impedance: 2.7 ohms
the 2 speakers on my saddle bags are 6x9 Polk MM691
Peak: 600 watts per pair / 300 watts each
RMS: 250 watts per pair / 125 watts each
•Recommended power range: 15 - 125 watts RMS per channel
•2.7 ohms impedance
my issue is trying to find an amp. all of the speakers are 2.7 ohm what is a good amp I should look for?
I am looking to build a crazy loud system.
I am also looking for a small in size amp as I plan to install it in my front fairing.
can anyone give me a recommendation on what amp would be best for my setup.
There are lots of micro amps that make a lot of power now. Anything from a major brand that is marketed for Powersports applications will do. I've used Cerwin Vega Bomber amps and I actually have a B2 powering my midbass woofers that's given me 0 issues over about 2 years. There is also JL Audio, Rockford Fosgate, MTX, Arc Audio and I'm sure the list can go on. You would need to run two amps due to the 2.7 Ohm impedance of your speakers. Each speaker would need 1 amp channel.
An example would be Cerwin Vega B54 plus a B52 for the 6x9s.
baggerproject
baggerproject
texas
k5james
Decebal
    Jun 10, 2024
