Mounting screws touching rubber surround? Okay, or totally bad?
  • 1
Fsco
So I have just popped in 4 Polk db651s speakers in all the stock mounting positions in my 00 Jeep XJ (Cherokee for non Jeep ppl). The back was plug and play with the mounting. The front I had to drill a new hole, but they're in the same spot.
My question is this: In the front, the (reused stock) mounting screws press slightly into the rubber surround. I ground the screw flanges down so that they are smaller, but they still touch that rubber surround a bit.
Do I need to grind them even narrower so that they don't touch at all? Or as long as there aren't sharp edges touching will it be okay?
VERY newbie question, I know. I'm just trying to cut right to the chase. They're being driven right off a Kenwood eXcelon 598 head unit with stock wiring.
Thanks, I really don't want to ruin my brand new speakers (that sound amazing to these ears used to listening to 14 year old stockers).
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
6
292
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
5K
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
Fsco
Fsco
Lansing, MI
Fsco
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
