MTX RFL
something that can pump and pump and pump and pump more and more power, those RFL's are NUTZ! For god sake it comes in it own crate! I was looking at them, but I dont know anyone who has them. How do they sound and do they really perform as they are said to? They giving the Stroker a run in the SPL category?
well, they sound like total ****! even the company that makes them say that. as of what amp i dont know, but just get an amp that puts out like 1500 or so watts, because since this is a mainly spl sub i doubt youll be doing more than just burping it for a few seconds. you arent planning on actually putting this thing in your daily driver are you?
get a directed amp they can push a **** load of power if you can afford the sub you can afford a dam good amp to go with it
They are made only for a SPL burp. If you want to play music on these suckers you'll have to recone them every day.
Just the same as you will blow up the engine of a drag racer, if you use him daily to drive in your town/city.
So only if you want to compete at SPL contests, this Real ****ing Loud subwoofer can be your choice. Power him up with 4 huge mono-amps (2 at each voice-coil), like the MTX 81000D. Build a huge box with even a bigger port, find that sole frequency to use, and you'll kick ass of those Stroker subs. But otherwise stay far away from the RFL.
Those RFL's are ****. DD 9515's kick their ass all over the place. For an amp? Id say either two DEI 1100d's (one for each coil) or one Earthquake D2.
Go to the US amps website and im sure you will find what your looking for (3000*1) heh heh heh mmmmmmmmmmmmm power
Take the mouse away from the "reply" button on 3 year old threads. Now, find a fork, and kill yourself. Thank you, come again.
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
860
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
basscrazy3127
basscrazy3127
WI
DBfan187
