Multi-layered Physical Security
  • 1
gstokes
FÜKENGRUVEN
I installed an top-rated 2-way paging alarm along with additional sensors right along with my stereo equipment, while the 2-way paging alarm has given me peace of mind by already thwarting an attempted break-in it also convinced me i need more protection.
I have been wanting to install a device to prevent the doors from being opened such as those Slick Locks, Shackleless Hasps, Slam Locks, Dead Bolts or even Electromagnetic Dead Bolts but the price kept me away, anyways i put together a list of potential cures for your particular security concerns, the Key-Rex security fastener is very unobtrusive and simple device that could simply be screwed through a door into a nut fastened to the vehicle body or chassis, have to unscrew the bolt to open the door and if you can't unscrew the bolt, oh well..
None of these options will prevent someone from smashing a window and climbing in but there's not too many people that will risk climbing into a vehicle knowing that the doors won't open, especially a truck or a van and with the alarm blazing it makes it even less inviting.
When a thief see's that you've taken bold steps towards securing your vehicle he will move on to the next..
Slick Lock for Ford E and Chevy G Series Vans $70/each, great price
Slick Locks Hasp Lock Systems - Drill Free Vehicle Security
The Blade by Slick Locks Ford Full Size Econoline Van
Babaco Stealth Lock for Ford E Series, probably the best security system available but requires installation at their New Jersey location
Stealth Lock for Ford Vans, Service Van Locks
Key-Rex and Penta Plus Security Fasteners, a very simple and effective solution
http://www.brycefastener.com/?gclid=CK2o2_H9_r4CFQIIaQodUEsArw
Built-in Keyed Lock $13
Products - Built-In Keyed Locks - 1710 - Master Lock®
Shackled Hasp $10, could be used on most any vehicle door and/or tailgate
Products - Hasps and Hasplocks - 731 - Master Lock®
Hasp with Puck Lock $40, best price you will find anywhere
SGM Enterprises LLC :: View All Products :: Hasp with Puck Lock
Electromagnetic Dead-Bolt, the possibilities are endless but since it requires a power source to operate these are the last option..
https://www.google.com/search?q=electromagnetic+bolt&safe=off&espv=2&source=lnms&sa=X&ei=DoGeU4i_H8WYyASlv4DIDg&ved=0CAcQ_AUoAA&biw=1360&bih=600&dpr=1
Don't forget to secure the hood and prevent it from being opened..
Hi all, looking to add a pair of speakers to the outside of our caravan. Currently the van has 4 ceiling speakers running off the existing single...
Lower the ohm the thicker the wire. The higher the ohm the thinner the wire but will have more windings. Lower ohm coils have a slight edge when...
gstokes
FÜKENGRUVEN
gstokes
Beaverton, Oregon
gstokes
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
