My 1st build on my own
  • 1
IndySlim
CoolAssDude
140
19
Omaha NE
So guys I've been researching this build for about 8 months now because I was learning at the same time. I'm going with 2 jl audio slash/500 amps (because I already own them), 2 12 in. kicker Q subs ( I know they'll be underpowered but jl amps are underrated any way so I should be fine I'm thinking closer to 600 watts rms the subs are 850 watts rms), ported box, I already have alpine r-s69 6x9's and alpine r-s65c.2 components, I'll be adding a alpine R-A60F 4 channel amp (hopefully I can catch a deal on one somewhere they're kinda pricey) to my interiors. I would love some opinions on whether I'm underpowering the subs to much and power options extra battery, bass cap or, H.O alternator (from a financial/performance standpoint). I plan on building an amp rack I've never done that before (I could use some help with that). my car is an 1999 oldsmobile eighty-eight anniversary edition if that can give you an idea of the space I'm working with. I ordered knu konceptz power wire (for my big 3), power block pos and neg., battery terminals, pin connectors etc. I went with them because I already have their wire installed and it works just fine. I have some of these pieces already so I'm open to any opinions, concerns, or ideas as far as underpowering the subs, power options (basically which should I go with or what power combination I should use) and amp rack ideas I'm literally in the have no idea what to do category on this one.
Ive seen so many amps done this way over the years. Especially ones that had the Molex plugs and a couple others
9
692
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I honestly think that stock locations work great for 90% of the people. With today's DSPs, you can move the listening position anywhere you wish...
929
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
706
IndySlim
CoolAssDude
IndySlim
Omaha NE
IndySlim
Latest topics
