my amp keeps cutting out...why?
  • 2
audioman
11
michigan
i have a jensen XA2100 200 W amp. it is pushing 2 12 JBL's 4 ohm. i have it bridged, and am rumming the speakers in parralell. it hits good and sounds fine but the protect function keeps coming on when i try pushing them. can anyone tell me why? i know jensen is not top of the line... but it is what i have for the time being. my old mtx amp kept blowing the fuse when i had it hooked up the same way also. please help!!!
hey man I happen to have some experience with those speakers the stereo store I used to work for carried jbl speakers. We had several people have the same problem. The answer is actually 2 things. First a Jensen amp is not designed to handle a 2 ohm load (if you have your speakers paralleled that is what the amp sees) also, If you have a meter, you will be able to test the actual speaker resistence and you will probably find that your jbl speakers say they are 4 ohm but in fact read less in turn putting more stress on your amp. My suggestion would be to put your amp in stereo or series your speakers. Wire the positive from one sub to the amp and the negative from the other sub to the amp, and wire the remaining pos and neg together on the speaker
it comes tomorrow and i cant wait. Thanks for spotting that amp and recommending it!
19
4K
6
117
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
295
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
304
audioman
audioman
michigan
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
