my amp wont stay on
uriel espinal
Alright i am new here and dont know much abt car audio all ik is that i like it i recently been having issues with my amp it wont stay on i reconnected all the wires and whrn i reconnected the remote wire it turns on for a few srconds i checked the fuses it stoped all of a sudden thought might have been a cable loose but checked it all any suggestions
Thanks in advance
Could be bad remote.
To check that, real simple test- take a small length of wire and connect it to the remote in on the amp AND the power terminal.
See if the amp stays on now.
Disconnect the remote wire first though.
I got the from an extra fuse i put it when i installed the head unit the head unit no problem but the amp i changed the ground the disconnected every cable and still wont stay on might it be burned amp
You could run that sub on a 4 channel amp and have 2 channels left for amping front speakers. I just put a small system in my brothers car with a...
16
3K
Two subs, same issue, two LOC's same issue, seems to me that there is an issue upstream. Have you tested the amp disconnected from the signal...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
319
6
455
uriel espinal
uriel espinal
chicago
uriel espinal
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
