My amp won't turn off? (WTF)
ok guys you really need to help me out! I got my red acc connected to my red acc,got my 12 volt constant hooked to my yellow 12 volt constant ground to ground, light blue remote to light blue remote? everything is hooked up right according to the manual?
ALSO when I take the remote off the amp it turns off? I just don't understand the remote is hooked correctly
I just had this same issue, I'm using a Loc. Problem is you need to disconnect the yellow wire from your amp and it should work then.
Subs play to the beat with gain low but if I turn it up my subs play loud unwanted never ending bass that is constant and wont stop until I turn...
252
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
460
adammk5
adammk5
Houston, TX
Nhiles711
Decebal
    Jun 10, 2024
