my box?
Box volume after subwoofer displacement is 4.28 cubes.
And with the calculator I used, I figured you're tuned to around 26.5 hz which is a very low tuning. Not sure if it was accurate with the calculators I used...
Box Volume = Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
Port Tuning = Port Length Calculator
And I just kept typing in different frequencies until it said a port length of 18.1 which is right at 26.5hz. This number seems low as hell and I might have just put something in wrong, lol.
Your box is 3.89 tuning I haven't messed with yet but probably a little higher tuning than you thought
Ya I got 3.78 after displacement of subs and port. Tuned at 28.88hz.
Its a box that I got with my skar audio subs. Its supposed to be tuned to 32hz. And I would think it should be at 4 cubic feet.
if I cut my port back so its at 32hz would that help with the higher bass?
make a new box. you only have 26 sq" port area. you should have about 14-16 sq in per cu ft. thereby a a 4 cube box should have around 60 sq inch of port area- so a 15" x 4" slot would work much better, also the port would get longer the more area it is.
Can someone check this for me? Box for two vvx 12. 37w 17h 21d
port 4w 15.5h 32d. Port in the middle of the subs. 45 in port. I got 32.64hz and after all displacement 4.07cuft. 62.0in port area.
What should the port area be for round ports?
Start by laying the larger bottom panel in an open space, then slowly “dry” assemble it by laying the pieces where they go like a puzzle. It...
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
440
The it to a custom air brush guy and tell him what you want. You can always stain, plexiglass windows, and put led lights inside the box. Search...
6
634
Thanks man! Quitting drinking and battling DRESS syndrome has given me a new outlook on life.
8
946
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
771
Colossus281
Colossus281
Albuquerque nm
Colossus281
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
