My Crossfire VR404 Died. Need Recommendations and Help!!!
  • 1
badstang123
I have a Crossfire VR404 which is their 4x50 watt amp. When I turn the vehicle on the green LED lights up stays lit for around 5 seconds or so and then it starts turning off and back on every second or so (Mind you this amp has no protect mode). If the head unit is playing music while this is happening for the second the amp is on it will play music. Also note that I had some engine whine before all of this happened.
To isolate my problem with the amp turning off I tried disconnecting the rca's with no difference and also disconnected the speakers with no difference. I then switched in a 2 channel I had laying around to power the front speakers and it works flawlessly. The engine whine even went away. For this reason I do know it's the amp. Also the sub amp worked with no cutouts throughout.
I have two questions. While I may be capable and able to learn I am not knowledgeable enough to repair it myself and don't feel like trying. First does it sound worth fixing? If so what do you guys think a repair would normally cost? And second is there anywhere near 91350 (SoCal) that repairs car amps. Thanks.
- Justin -
  • Locked
Looking to buy a Crossfire CX2L. Anyone selling one? Serious buyer.
Yep.3012r and 33.never drop below 14.1.have the jp84 as well.solid electrical.
17
4K
It should last 10 years. Unless you are constantly cranking the bass up to the max. Do the big 3 in 1/0 wire, and have a solid battery or two...
7
badstang123
badstang123
Los Angeles, CA
badstang123
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
