My Friend cut the end of my battery cord that goes to my amp
Rik Is Ripe
12
Ga
My Friend cut the end of my battery amp and now I cant connect it to the amp. It's connected to the battery. How do I get another circular terminal connecter? Or where do I find them so I can connect it to te end of the wire.? I don't want to have to buy another so.. Where can I find another terminal? I have my old one but I can't open it back up for nothin. Please help!!!
Yeah. there like a dollar at a hardware store. Or be the cheap *** you are and stuff the wire sumwhere on the positive terminal and tighten it down..
any links to free chat gpt 4 access? I haven't been able to find anything that isn't behind a paywall.. I want to take this cyber bish for a ride.
29
3K
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
249
If you buy a replacement OEM Radio Harness the colors will match up then you can use a wiring harness to connect to that. According to a few...
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
8
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
9
Rik Is Ripe
Rik Is Ripe
Ga
Bettr n' Revrse
winkychevelle
    Jun 3, 2024
