My sohc vtec blows smoke at wot
infamous_e46
hArRy_DaNgLeRs
26,366
California
Sounds like bad rings or valve seals. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif If its the latter of the 2 its a fairly easy fix. If its the rings its a lot more work.
compression check will reveal rings if you put some oil in thur and the reading goes up, its rings. And honestly, if its valve seals, and its not buring a **** ton of oil, i wouldnt worry about it
drove my old 3.0 acclaim for 2 years with bad valve seals. it burned a quart between oil changes. Not too bad i guess.
probably got the gain turned waaay up. Also remember this is just a 2 ohm stable amp. Make sure your subs are wired for a 2 ohm load on the amp...
4
infamous_e46
hArRy_DaNgLeRs
infamous_e46
California
pelekeliko
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
