My subs ain't subbing no more. Help.
  • 4
Name'sDEEZ
CarAudio.com Regular
121
15
Earth
Yo i need some help. I'm getting a mental block on determining the problem. I was driving back home and i hit a dip on the road that made me bounce and made my amp cut out.
I checked it and all connections are fine. I put the multimeter and im only getting 3 to 4 volts on power and remote wires.
I checked fuse by the battery and it was good but still i swapped it since its been there for a while.
What else can i do before opening it up?
Thanks in advance.
Update: i got it to power on but it cut out when the bass got to heavy.
Thanks in advance.
Check your voltage on each side of the fuse holder.
I hooked up another amp and no work. The power led is on but dim @Bobbytwonames @SlugButter @1aespinoza
Is the battery terminal clean? You have refreshed fuses and connections so only thing left is that terminal and ground point. If it is a car/suv, I suggest running a ground from the engine block to a strut tower.
What do you mean disconnect? So i would only be testing ground?
What I meant is disconnecting the amp and testing the bare wires with the MM.
Brahmas are nice. I have a 10" Mk1. Just a single 10 was enough for me.
19
946
These are also very good drivers, some of the best bang for the busk on shallow mounts. DD Audio SL610-D2 10"...
5
679
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
566
Name'sDEEZ
Name'sDEEZ
Earth
1aespinoza
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
