My subs start fading when both are connected. Help?!
woe_ismitch
I moved my entire system from my Pontiac Grand Prix to my new Jeep Wrangler. Everything is hooked up right. I have the right wiring system. My amp is a 1000w Sony Xplod powering two 12" Dual subwoofers with 500w peak each. In my grand prix, they sounded spectacular, both of them were wired up and worked. Now when both are wired up in my Jeep, they sound awful. When only one is connected, it sounds fine though. The only thing i'm using is a different head unit. It's an older Pioneer head unit. Could that be the problem? I'm a little new to all of this so help would be great! Thanks.
sounds like you have them out of phase man,reverse the speaker wires on one and see if it sounds better,thats the first place you should start,if thats not it then go from there
when i have one sub connected, it works just fine, sounds just like a 12" should. as soon as i add the other one, they both lose their power and sound awful. i have switched the wiring and changed them around but that doesnt seem to be working.
i've switched them one at a time, that didnt seem to be working so eventually just bought new speaker wire for both of them and that still didn't fix it.
ok are they both wired together or one speaker on each channel?
i have a Sony Xplod 1000w amp and they are just wired directly to the two ports on the enclosure i have. on one channel. i have the negatives on one side and the positives on the other, from each sub.
Okay, I keep learning and keep asking questions. I am abandoning the replacement of the stock sub. Too many variables. I'm now considering a...
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
412
If they had an orange basket I would have to buy them.... Hmmmm Sell my 4 Xs and get 6 of those and do no-wall again with one more 4500..... :unsure:
4
546
That’s the little single 6.5 inch enclosure. The Savard did just as well as the RDS. These subs do well in ported or 6th orders but not as well...
12
821
woe_ismitch
woe_ismitch
aurora, OH
skylineTT
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
