My subwoofer in my car pulses when i turn my car on.
  • 2
Mr_Beastly12
CarAudio.com Newbie
Hi i hooked up a scar audio 12 inch sub in my car. I hooked it up to the speakers using speaker imputs in a planet audio amp since i couldnt find a scar one with speaker imputs. But i used the speaker imputs since i didnt put a new head unit in. And it works perfectly when i just turn the ignition on. But as soon as i turn the car completely on the sub starts pulsing for like a minute then stops. I know its not the amp or the sub because i swapped out a different sub and amp from another vehicle that works perfectly and it has the same problem. Do you guys have any idea what my problem could be?
That sounds like a ‘ground loop’ . I have had the same problem when trying to use the speaker level inputs on an amplifier. You can try moving the ground wire for the amplifier to a different location. But in my case, the fix was to use a separate line output converter.
I just got the line output converter and put it in, and i have the same problem.
You can add a passive x-over between the HK harness and Logic sub. Just know that an inline passive will also affect the HK sub's frequency curve...
5
The Biden administration on Tuesday backed down on a controversial proposal to direct the IRS to collect additional data on every bank account...
31
6K
Google and Ebay are your friends. Froma quick search and providing these are like new, $2- $400 for the subs and $2- $400 for the amplifiers...
dragon.breath, Many thanks for taking the time to help me out. It is very much appreciated and my small brain can understand it now. I have...
6
774
To do this magic, should the microphone always be kept in the driver's seat or on the dashboard?...since that is where it must go in phase with...
Mr_Beastly12
CarAudio.com Newbie
Mr_Beastly12
Minnesota
Mr_Beastly12
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
