Need 4 channel!
i have a alphasonik pma4150a running 150x4 and 240 watts x 4 @ 2ohm
480 watts x 2@ 4ohm Ran it for about 1 month beforei had my soundstream vga320.4 repaired its bada** man no complaints great sq great build etc...
Hour Meter
Remote Mount PMA100V Digital Volt Meter
Heavy Duty One-Piece Extruded Aluminum Heat Sink
Beveled Clear Acrylic Protective Cover
Tiffany-Style RCA Jacks
Parallel Line-Out RCA Jacks
MOSFET High Speed Switching Power Supply
Milspec Double-Sided Glass Epoxy Circuit Board w/ Through-Hole
Plating
Heavy 4 oz. Pure Copper PC Traces at All Preamp and Amplification Stages
Solid Brass Nickel-Plated Terminal Blocks (4-Gauge Power, 8-Gauge Speaker)
Variable Low-Pass Filter: 50Hz~250Hz, 24dB/Octave
Variable High-Pass Filter: 50Hz~250Hz, 24dB/Octave
Variable Subsonic Filter: 20Hz~60Hz, 24dB/Octave
Variable Bass Boost @ 45Hz: 0 ~ +18dB
Variable Phase Shift: 0~180¾
THD:
Signal-to-Noise Ratio: >100dB
Frequency Response: 5Hz~50kHz
Input Impedance: 10k©
Input Sensitivity: 200mV~8V
4-Way Protection Circuitry: Thermal, Short Circuit, Overload & DC Offset
Cooling Fan
what if I wan this AMP with a P2 Rockford sub https://rockfordfosgate.com/products/details/p1000x5/ Had one shop quote me at 1100 for everything...
15
4K
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
277
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
673
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
439
bradfordpoole
bradfordpoole
Statesboro, GA
reflecting
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
