Need a good 12" recommendation
gm2
have an amp and box already. Hoping to pick up an awesome 12" that will work well with both.
amp is:
200W x 2 chan. RMS @ 4 Ohm Stereo
300W x 2 chan. RMS @ 2 Ohm Stereo
800W x 1 chan. RMS @ 4 Ohm Mono
Box is:
14"x14"x16" O.D. .75" material = 5.7 cu ft ID? not sure I did the calculation right...
Trying to stay under $100
Here's what I've been looking at so far:
REF-TM12.4 - 12" Tidal Audio Subwoofer Dual 4 Ohm OEM by Image Dynamics
running the 1x800 @4 split
any better suggestions?
The box you have built is 1.31ft^3 before sub displacement. The Tidal sub you listed will not work well with that amp. You want something that will give you a 4ohm final load, so a SVC4ohm od DVC2ohm sub is what you're after.
I am looking to replace the factory head unit on my wife's 2011 Subaru Forester XT Touring. The car has these features we would like to retain...
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
595
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
409
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
455
gm2
gm2
Knoxville, TN
gm2
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
