Need a little advice/help...
  • 4
mariojas
Hi guys I have a quick question for you all: I want to get 2 Kicker 10CVT12-4-N which are 400watts RMS 800w Peak each single coil 4ohm . I would run them parallel so total impedance will be 2 ohm.
This is what I dont know. What amp should I get? the zx750.1 which has RMS 2 Ohms: 750 Watts x 1 Channel and peak of 2 Ohms: 1500 Watts x 1 Channel
or the dx500.1 which has RMS 2 Ohms: 275 Watts x 1 Channel (d 1% THD+N) and peak 1 Ohm: 1000 Watts x 1 Channel
I'm not sure Im getting mixed answers hopefully you guys can help me straighten this out..
Thank you
2 subs are 170 and the zx750 amp is 270. And that is my price range... unless if you have any better setup suggetions for that money? I'm open to suggestions.
I already have the car wired. I dont know I never heard of audiopipe... I'd rather pay more and get a brand named amp. What about subs? Do you know anything about them good/bad? or "better" ones around that price range?
The main reason bass boost isn't used is that it only boosts frequencies within a very small range, and often causes the amp to clip at a lower volume level than if the boost was off. With it off, you have a nice amount of mass over more frequencies at a higher volume, compared to a little extra bass at a certain frequency with it on.
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
307
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
691
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
448
Very nice to hear you found what you needed to get your audio system/ect. up to your needs. we appreciate the information provided in this thread...
4
498
mariojas
mariojas
Cleveland
disturbed471985
