Need advise on an upgrade to the speakers I currently have.
  • 2
LJBennick
Right now I have two pairs of Kicker 11DS525 5-1/4" Coaxial Speakers and I am thinking of upgrading. The speakers have treated me well and I honestly wouldn't mind staying with them, but they definitely lack in a few things (mainly the bass) and I know that the sound in my car could be improved with a new pair of speakers. I am willing to pay around $200. Thanks for any input.
But you a pair of exodus anarchy mids, and issue them with a tweeter.
You could probably even pair them with a 3"mid that can play close to 20kh.
This option will most likely require a mod.
As far as another 5.25 coaxial that had midbass fur under 200$ idk. Rockford makes good budget components that have decent midbass output.... Idk about there 5.25 though...
Think it's going to be hard to get midbass from a 5.25 anyway.....
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
192
You can just change the surround if the cone is not broken. This picture shows all the measurements you must make.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
9
137
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
144
LJBennick
LJBennick
Ogden, Utah
calebkhill
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
