Need help asap
  • 4
What's the best box to build for 3 kicker l7s with about 45x50 inches to play with
Best box?.. that's pretty vague. This went into a Dodge Magnum and pounds.
I suppose it could have been bigger but the vehicle had space constraints and its getting a Korean 4K wired .67 once his electrical is solid so it's sized about right imo.
You always have some nice specs for enclosures man.
Perfect
So you have an 800 watt sub (1600 is a peak spec, ignore it) the SVR-10 - 800 RMS dual 2VC ohm wired in parallel for a 1 ohm load paired with an...
88
694
747
970
Mikey0075
Mikey0075
S.c
Mikey0075
    May 19, 2024
    May 19, 2024
