Need help choosing appropriate 5 channel amp
I have an amp I want to sell.
Skar Audio - 5 channel 700 watts
Never been used or installed
Box was opened though but uh 150$..
also there’s another thread on here selling a 950w 5 channel amp @Speedfreaq
If I were you I'd try my hand at getting a Cerwin vega CVP2500.5D it is 2ohm stable and has more than enough power for your needs. I personally run this amp and have absolutely no complaints at all. Been running it hard and loud for about 6 months now and not a single peep of running hot or anything like that. I have my setup wired for 2ohm- all 5 channels. But I would also highly recommend doing the big 3 with 1/0 Awg in your engine bay and 2/0 Awg from there to a distribution block in the back of your truck cab and 4awg from dist. blk to amplifier , upgrade your battery to a AGM or better and upgrade your alternator from the stock 130 amp to something to the order of 250+amps -(think Js alternator, mechman or others).
Here is my thought, theory. Those speakers are 80w rms. Half of that is 40w rms. Add the 40 to the 80 and you get 120w. Get an amp that is 120w...
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
I have 2 Sundown SA10v2 (1000w version) and just replaced my RF R1200 with a T-1500.1bd and OMG! I was considering Ampere Audio, JP23, Sundown...
5
well, thats kind of an open ended question....., you can do 2500rms@1ohm, or you can do a pair of 1k-1200rms@2ohms. just have to know the amp...
5
Titan82
CarAudio.com Newbie
Titan82
Pennsylvania
Grumppy01
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
