need help goliath fried
  • 3
ang3l729
8
al
so i had a system installed a few years ago, consisted of: 0 gauge through out 2x250A from starting batt, the same before secondary kinetik 3800..hifonics goliath pushing 2 cerwin vega strokers 2k rms each in custom ported box...now the goliath fried (idiots did not fuse the amp) then wrecked the car shortly afterwards...kinetik battery is now dead..and amp...well local repair shop said not repairable..so ran new wire (0 gauge in new car) (big 3 upgrade) new kinetik hc1400 will be pushing brutus brz2400 n it (1) stroker in sealed box...my question...how the heck do i fuse this now? recommended 250 for amp, but but what about between batteries? 300A at each? will also be running another 300 rms for tweeters for now and later door speakers,..please help
well you fuse for the maximum amount of current the wire can take safely, google wire amperage chart it will show you feet vs amps and use that to determine the largest fuse possible for minimum impedance.
im usually not this slow i swear, just so frustrated with working on all this that im very lost....
---------- Post added at 11:30 PM ---------- Previous post was at 11:30 PM ----------
Should take some pics if youre going to make a build log thread.
and ima have to go back and take some, i just joined today cuz alot of what i googled comes from here, so still a newbie sorry, dnt even know if im in the right place
Lifelong Pioneer Premier series user here. Switched to the Kenwood eXcelon Reference (XR) DDX9905S and never looked back. Excellent sounding...
9
691
11
967
933
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
ang3l729
ang3l729
al
ang3l729
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
