Need help please
  • 2
Clayton6777
CarAudio.com Newbie
I’ve recently installed my system into my new car I have an lc1 from my factory front speaker wires grounded and powered from the battery their is a remote in wire fused into my factory usb port sense it turns in when the car does and then a factory out running to ky amplifiers, from the rca ports on the lc1 those run to an equalizer and from the equalizer my sub rcas run back the the sub amp sub amp rack is connected to ground on chassis and gets a 4 gauge power wire ram back to it from battery I have a bass knob installed from the amp to my driver seat and all the way down turns the sub off but the second I turn it on just a little bit I get either a loud bassey tone that plays constantly and the more power I give the amp the bassy tone I get turns into a loud thump thump thump every .5 a second or so and my car has eco mode so when it turns off at the light and the subs are still playing the noise is gone I have a ground loop isolator installed I’ve tried running different rcas to the sub nothing please help
So you're planning on running active and using the amp or head unit crossover for the tweeters? Is that sub channel full range and have separate...
926
11
512
619
https://youtube.com/@SaabUnleashed?si=-8qdxpYY0yGzrMsL Here you go. This guy does android head unit reviews. His reviews are how I found my...
7
887
Clayton6777
CarAudio.com Newbie
Clayton6777
Buffalo
AnthonyO
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
