Need help setting gain
  • 3
OllieCollie
CarAudio.com Newbie
USA
I only use Spotify to listen to music and I used a 40 Hz test tone and use the multimeter to set the voltage to 27v ac (28.28v ac is the spec) but when looking at the voltage for some songs it will jump around and peaking around 35v ac. Is this okay/normal? Is it just getting peak power and is fine rms wise? Is there a better way to do this? Just don't want to ruin my sub. Thank you in advance!
11
749
770
OllieCollie
CarAudio.com Newbie
OllieCollie
USA
1aespinoza
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
